Status
Not open for further replies.
1 - 4 of 4 Posts
I was sure I'd seen this subject before, but a search isn't turning up anything. Does anyone have discreet Pronto codes for the 2 component inputs on the Panasonic Tau CT34WX50?. I suspect any late model Panasonic with 2 component inputs would be the same.
Tony
Tony,
I used to have a Panasonic 56" HD RPTV with 2 component inputs and could never find the discrete code for the 2nd component input. I tried all 255 "advanced codes" with a OFA Cinema 7 remote. I used a small macro that went to input 1 and then did next input. It worked well. Good luck.
Jay
I saw these at remote central a long time ago and forgot they were there. The function labeled "Video 4" is really component 1. This worked for my PT56WXF95. Here is the link:
http://www.remotecentral.com/files/i-pan.htm
***edit***
I found this from an old ccf file. This is for Component 1:
0000 0071 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0011 0aad
This is for "next input" :
0000 0070 0000 0032 007f 0041 0010 0010 0010 0030 0010 0010 0010 0010 000f 0010 0010 0010 0010 0010 0010 0010 0010 0010 000f 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 000f 0010 0010 0010 0010 0012 000f 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 000f 0010 0010 0010 0010 0010 0010 0010 000f 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 000f 0030 0010 0010 0010 0010 0010 0011 0010 0010 0010 0010 0010 0030 0010 0010 000f 0030 0010 0010 0010 0010 0010 0010 0010 0010 000f 0030 0010 0ac1
I used a 2 second pause between them and it worked fine.
Jay
[This message has been edited by jerndl (edited 06-29-2001).]
1 - 4 of 4 Posts
Status
