Status
Not open for further replies.
1 - 4 of 4 Posts
This is my first post so I'll start off with a dumb question and hopefully improve the quality of my questions as time goes by.
I just got the Dish 811 HD receiver and find that the remote is UHF. I grabbed another Dish remote, an IR, from a different receiver in the house to see if it would work at all with the 811. No, it doesn't work.
The Pronto fails to learn the UHF signals when trying to do a remote to remote learn. What do I do? Is there a solution to this?
Thanks, David
Discussion Starter · #3 ·
AnthonyP,
Thankyou!! The codes from the 6000 model do indeed work on the 811. Downloaded, modified, loaded onto the TSU and they work great. BTW, the IR remote I grabbed was from a 301, one of the base models.
David
1 - 4 of 4 Posts
Status
