Status
Not open for further replies.
1 - 1 of 1 Posts
Ok, if anyone has a good link or suggestions for 6.1 speaker placement and selection (particularly the rear channel) I would really appreciate it.
Also, perhaps this should be a seperate subject, I am looking for speakers. I'd like to think my budget would be $1,200 - $1,500 for the front 3 and about $750 - $1,000 for the sub + rear channels. I have a Onkyo 797 if that helps in the selection. I haven't come to a conclusion on an amplifier yet and will probably use the 797 until the extra money comes available.
Room dimensions: 11.5' x 19.5' x 86" (with a low spot to clear a I-beam in the center @ 80") which should equate into just shy of 1600 cu ft.
Walls are in process of being treated with acoustic abatement material and fabric cover.
1 - 1 of 1 Posts
Status
