Status
Not open for further replies.
1 - 4 of 4 Posts
· Banned
Posting for a friend -
"I noticed
> the other day that there was some sort of smudge on
> my
> screen (looked like a fingerprint, the FBI is
> investigating), so I was wondering how to clean it?
> Are LCD projection screens just glass, and I can use
> Windex or 409, or would I be better off using a
> product more suited for TV screens?"
please be specific of what to do and what not to do.. Thank you very much.
· Registered
DO NOT use Windex. It contains ammonia.
I use Fellowes screen cleaning wipes. They are ammonia and alcohol free. Some recommend just plain water with microfiber cloths.
Of course if you really meant LCD projection screen, and not LCD direct view screen, the answer may vary.
· Registered
Pioneer say that Windex type cleaners may void the warranty, they recommend a damp cloth ( a cloth comes with most pioneer panels). Monster also make a cleaner suitable for panels but I would only use it if the damp cloth does not remove the finger prints.
1 - 4 of 4 Posts
Status
