1 - 7 of 7 Posts
im from the UK and have a PAL PS2 slim.
Basically i was using an RGB Scart lead for ps2 until recently buying a 3 in one component cable for my PS2 (lead can also be used for 360/Wii/PS3) http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
My question is although the picture is sharper i can see vertical lines on the screen during gameplay especially when performing fast actions (For example when i was playing onimusha 2 in 60hz).
should i get another component cable: http://www.play.com/Games/PlayStatio...&ob=Price&fb=0
rather than the multi purpose component in the first link, is it a pal component cable issue on HDTV's?
thanks for any help.
Can you elaborate on "i can see horizontal lines on the screen during gameplay" or provide a screenshot? This sounds like it may be screen tearing? You can google for example images or YouTubes of this to compare to what you are seeing.
Those no-name cables, especially the switched multi-system ones like what you bought, tend to pass very poor quality signals. I don't know what you have available over there, but if you can get your hands on a decent name-brand cable set like Sony, or Monster, that should help.
Discussion Starter · #4 ·
iits def' not screen tearing, its vertical lines that run through the game and is easily noticible. sorry about that confusion
thinking about buying a ps3 only component cable to see if that'll rectify the problem but im not sure yet
also when i play my wii games through its component cable with the component box i have no issues, so maybe it was the ps2/ps3/360/wii component cable i was using linked above?
FWIW... I have used PLENTY of no-name cables with no issue. To that end, I still use my 4-in-1 (or whatever it is) component cable which I purchased off of eBay which has the THINNEST cabling I've ever seen and it works fine. It's at least a year old now too and been through a move.
That said, cables are relatively cheap to replace (even if you are buying name brand except for Monster) so it's worth a shot. If that does not rectify the situation you may have a problem with your PS2 itself or the TV.
Oh wait a minute... I just thought of something... you said you are using a 3-in-1 cable. Do you have anything else connected to the 3-in-1 besides the PS2? That might sound like a dumb question but with some of these cables there are video problems if you have more than one device connected even if the other devices are turned off.
Discussion Starter · #6 ·
no i dont use the other cables in the 3-1 cable, i only use it for the ps2 to connect into the component box. and yeah i never used to have this problem when i used to use component on my 360 through the same hdtv or currently my wii. My ps2 slim isnt broken or anything either. thats why i was thinking maybe its a cable issue. Also the PS2 options is set to component and on 16:9 although technically my hdtv is 16:10 which i dont think is true widescreen but its fine for my 360/ps3 and wii uses (no borders).
Progressive vs 60 hz vs 50 hz
I have the same problem with my no name ps2 component cabel. But it only occur when running a game in progressive scan or in 60 Hz. 50 Hz works fine. Im starting to think it is the cabel. 60 Hz looks fine using scart.
1 - 7 of 7 Posts
