I bought a PS3 8 days ago and I can not get it to work with a DVI to HDMI connector. My HD 1080i projector (Optoma H76) will not display the PS3. It will only work with the yellow RCA cable. I called Sony tech support and they it's a 50/50 that it will work and that there is a video sync problem between HDMI and DVI. Does anyone know how to fix this? If not the PS3 is going back to Best Buy. Thanks for your help.
The connection looks like this.
PS3 - Sony HDMI cable - HDMI to DVI Adaptor - DVI cable - Optoma H76 Projector (the projector does not have a HDMI connection).
Thanks for your help in advance!
P.S. Sony tech said I should try the AVS forum to see if anyone has a fix.
Scott
Scott
