1 - 2 of 2 Posts
Ok so the problems I have I started seeing with Black Ops... It was working fine with no issues, then it started locking up about every OTHER game play after the multiplayer game ends. So now its happening more frequently to where I'm getting error codes (8001050F, 80010514) and movies are working sometimes and sometimes not. It is reading all the discs I put in and randomly locking up on them.
I tried taking is apart and cleaning the laser (cleaned ALOT of dust out!!). Tested with black ops, and thought it was fixed but then it froze again after about an hour of play!!
I am leaning towards it being a problem with the laser, but want to confirm before buying another one to replace! There was alot of dust on the drives controller board as well.
Can anyone confirm this is the laser and thats what I should order?
thanks!!
1 - 2 of 2 Posts
