Ok - strange issue here.
I use XBMC for standard def and light HD. (Just an Xbox modded with a media center)
I also use an A2 on the same TV, running through component cables. (same as XBMC)
The issue I am having is that a DIVX re-encode (720p, 3mbps) of planet earth episodes 7 - 10 look completely stellar on the Xbox at 720p compared to my BR PE disks at 1080p/i.
I dont know how to explain it, but a great deal sharpness and clarity is lost when I do A/B comparisons of the two. DivX should kill the HD look compared to full 15 mbps VC1 encode.
Any ideas? The ps3 does connect to the HDMI. I also did pull up the sony test patterns a while ago, but I didnt know how to use em, and I kind of just improvised on messing with the settings. SO maybe I screwed something up, but wouldnt the XBMC be affected as well? Or maybe settings only effect the specific input?
Im kind of lost. I compared some mpeg 2 caps (high BR, 18 - 22 MBPS) but they can only play off of the PS3 and not the Xbox. The MP2 caps were episodes 1-3, and they looked identical to the BR disks, banding and all. So maybe its a ps3 thing? I dont know. But the XBMC PQ on a divx re-encode of a MP2 cap just kills the HQ MP2 caps and BR disks.
I guess, since I messed with the calibration, could that do it? Other movies such as underworld and all look awsome. So part of me says it isnt the PS3 or tv, but the quality of the BBC VC1 encodes...
Any ideas?
Any ideas?
