Hi all,
Do 2-channel setups benefit from hi-def audio?
I have a PS3, for which I can either use the optical output to send data to a high-end DAC, OR I can purchase a home theater receiver that can handle all the new surround formats. Either way, for the moment, my system will be only 2-channel.
Not sure if the system reverts to the legacy soundtrack if you are running only two-channels, or whether you still get the higher resolution audio.
Please advise! Thanks.
