Hi,
I am using PS3 w/ Samsung HLR5667W (connected via HDMI). The problem is that screen looks darker when PS3 outputs anything RGB (for example, playing DivX). The RGB output range is set to Limited.
I did some experiment and found that RGB output is darker than YCbCr output by trying both YCbCr and RGB on the same blu-ray title. I am not sure if this is PS3 problem or Samsung DLP problem.
Can anyone confirm this? Do you have this problem w/ non-Samsung TV set?
