Originally Posted by rahzel /forum/post/15445803
Set BR/DVD output to YCbCr.
Set RGB to Full and your TV's HDMI Black Level setting to Normal (or Limited/Low).
Enable YCbCr super-white.
Make sure xvYCC is disabled on your TV.
For settings, look in the A750 calibration thread and try out the settings people are using, preferably with the same firmware as your set.
To be honest, it looks like playa has the color and sharpness WAY too high, and the backlight is higher than I would use.
I have the A650 which is essentially the same, but I wouldn't recommend using A650 settings with your A750.
Audio settings depend on your audio equipment, or more specifically your AVR capabilities and/or your audio equipment. But for the most part, if you're using optical for audio, set audio to Bitstream. If you have an AVR with HDMI repeating or you're simply using your TV speakers, set audio to PCM. For supported audio formats, if you're using optical or your TV speakers, just use the automatic settings. If you have an AVR with HDMI repeating, check all the audio formats your AVR supports.
Originally Posted by conroy9 /forum/post/15451796
I'm confused about what xvYCC does.
The manual says "increases detail and color space when watching
movies from an external device (ie. DVD player) connected to the HDMI or
Component IN", which sounds like a good thing to me, but some people say it should be disabled?
playa's backlight seems high to me too.
Originally Posted by rahzel /forum/post/15453069
So for the time being, you'll be using the TV speakers and the HDMI input on your TV? I would still go into the audio settings and select automatic and make sure audio output is set to PCM in the BR/DVD settings.
BTW, if you're unfamiliar with the PS3 menu, all the things I mentioned above are either in the BR/DVD settings menu, or the video settings and audio settings menus. Sony decided to split them up into 3 different sections.
There are other settings that may concern you, like the DVD/PS2 upscale options. There are three different settings - one turns the option off, the second upscales and retains the aspect ratio (for 4:3 movies) and the third stretches 4:3 content to 16:9. IIRC, "Full" is the one that stretches, but I forget what the other one is. There are other things like noise reduction which I leave off. I think there are additional settings that you can view when you hit the triangle button when you're viewing a video.
