1 - 4 of 4 Posts
Assuming it's the same as the G1 players, it's in the setup menu under the "maintenance" button. Click the "update" button and before launching the update applet it'll tell you what version you currently have.
My HD-D2 I picked up yesterday from CostCo had the 1.3 firmware. I downloaded the new 1.5 firmware (even though it said it was for the A2 and made no mention of the D2). Burned the ISO in a couple minutes and the D2 update went just fine.
Anyway, as geko mentioned, go to setup, and check out update under the mentenance menu.
1 - 4 of 4 Posts
