Unless you have a method of stretching the 16x9 image so that the panamorph will compress it back to the correct ratio, you move it out of the way.
Originally posted by madpoet Unless you have a method of stretching the 16x9 image so that the panamorph will compress it back to the correct ratio, you move it out of the way. |
Originally posted by jasonDono If the material is 16:9 and I set the projector to 4:3 it stretches the image vertically. Would this work? |
