1 - 4 of 4 Posts
Using a Crown XLS 1500-
Each sub is 4 ohms
2 subs connected in series for 2 ohm load. 2 subs connected to one channel, 2 subs connected to other channel.
Crown is rated 775w x2 for 2 ohm load.
If 2 subs are connected to one channel, is the power halved to 325w? I'm only assuming yes otherwise people wouldn't have multiple amps.
Originally Posted by DustinF  /t/1520859/question-about-power-for...el-of-pro-amp-4-subs-total/0_80#post_24435527
Each sub is 4 ohms
Yes, each sub would get app 387 watts (assuming 775 is actual power rating).
Discussion Starter · #4 ·
Originally Posted by BassThatHz  /t/1520859/question-about-power-for-2-subs-on-each-channel-of-pro-amp-4-subs-total#post_24435632
Series is 8-ohm, I think you mean parallel.
But yes, the power is shared amongst the drivers equally (assuming like-drivers).
Thank you, yes I meant to say parallel.
1 - 4 of 4 Posts
