Status
Not open for further replies.
1 - 2 of 2 Posts
I just got some 14 gauge speaker cables from home depot but usually with speaker cables it indicates a (+) and (-) however, with these RCa brand cables it shows neither. Both stands are indenticle. Will it matter?
No, it won't matter; as long as you keep the + from the amp/receiver to the + on the speaker and same for the - connections, you'll be just fine.
Usually, if the jacket is not specifically marked or the conductors are not different colors (i.e. one "silver" colored and one copper colored) there is a small ridge/rib on one side of the cable jacket to help you keep the polarity correct between amp/receiver and speakers.
1 - 2 of 2 Posts
Status
