1 - 5 of 5 Posts
My HTPC is connected to the internet using a wireless PCI adapter. However, I cannot get a full, reliable signal. I have tried to use the signal booster (those big antenna) and it did not help. However, my laptop always have a full bar and fast internet connection. Even when I use the laptop in the same place as my HTPC, the laptop will have full bar while my HTP only manage to get 2 bar. I am really confused. Is laptop just by design is optimized for wireless? I was wondering if a wireless range extender (repeater) will make it better?
do you get the same reception from the laptop if its right next to the htpc?
where is the antenna for the wireless card on the htpc , is it tucked in the back of the machine tucked in a cabinet?
Discussion Starter · #3 ·
The laptop always get better connection no matter where I put it, even next to my HTPC. The antenna for the wireless card is in the back of the machine and the HTPC is not in a cabinet.
What direction is the antenna on the HTPC adapter pointed. It needs to be pointed up the same as the antenna for best results and any metal such as the PC case if in the path between the 2 antennas will degrade the signal.
1 - 5 of 5 Posts
