If I have one DVC at 8 ohms/side wired in parallel, I have a 4 ohm load. If I do the same with two DVCs and connect them to an EP2500 using the L/R outputs on the back, I still have a 4ohm load correct? Based on the EP2500 specs: (1200 watts into 2 ohms), I would have 600 watts per speaker at 4 ohms...correct?
These two DVCs would be in separate 260L tubes. BTW, they are the same Dayton 15" DVCs I've had for years. They can handle 350 watts per coil or 600 watts total. I'm just looking for the best way to utilize the amp.
