Status
Not open for further replies.
1 - 5 of 5 Posts
If you have a 92" diagonal screen, much likely your pj is placed between 9.4ft and 11.7ft.
If so:
1) What is your seating distance?
2) What about SDE, VB and other monsters?:D
Luck
I have a 84", which is close to what you're asking for.
My seating is 1.5 times the width of the screen. So, if the screen is 6' width, then my seat is 9' away from the screen, and it gives me best result.
I have a 92" screen and my viewing distances in the room are 14' and 11'. IMHO 8' is too close.
seriously, you might want to compare result with particular PJ in mind. The PQ is different from model to model even with similar ss and viewing distance. Pick a PJ you have in mind and Screen Size then ask the same question again.
1 - 5 of 5 Posts
Status
