Bob,
you've always been very forthright in your answers on this forum, so I want to thank you in advance for taking the time to clarify a couple points about the IF7205 versus the IF7200:
1/ HD2+ dimple fix - is the main effect of this technology upgrade to improve brightness, CR, black-level or "filmlike appearance" (or any combination of these)?
2/ Fill-factor / screen-door - is there any difference in the fill factor of the pixels between HD2+ and HD2? This is another change that could account for the improvements in "filmlike appearance" that TI has announced, but I have heard conflicting reports over whether there is any change in pixel fill factor between HD2+ and HD2 - thanks to clarify this for me
3/ 7-segment wheel - I've understood the advantages this improved color wheel provides in terms of reduced dithering and "dark scene performance". My suspicision is that the improved brightness delivered by reducing the dimple and/or increasing the fill factor resulted in a projector which could provide greater brightness with the same lamp/wheel/optics, or a projector which could provide equivalent brightness with the same lamp/optics but using only ~90% or so of the color wheel, resulting in some "space" to put a new dark/green-neutral segment of improved dark scene greyscale performance. Can you confirm if the improvement from "10- bit pixel depth" arises only from the use of this new 7-segment wheel and that the effective pixel depth for "all the rest of the pixels" which are using the brighter colors from the rest of the wheel are essentially getting the same pixel depth between the 7205 and the 7200?
4/ optics - I think I read somewhere that the 7205 has new optics that completely eliminate the "barrel distortion" or "pincushioning" which was evident on the 7200. Can you confirm this - are the optics on the 7205 different from those on the 7200? Is the distortion really "GONE"??
Thanks again for your answers. I am one of the countless people who is deciding between "buying HD2 now or buying HD2+ later" and getting some clear answers on these technical points from someone like you who is in the know will be an important factor in influencing my decision.
-fafrd
-fafrd
