Hello,
Yes you can hookup local and cable as you have described.
It is necessary to assign the inputs in the installation menu.
As long as your Toshiba set is not more than a couple of years old it should accept yhe 1080i and produce an inproved cable picture.
The first and second? generation of the 65" and 56" Toshiba 16/9 sets had component video but did not accept 1080i.
Hope this helps.
Larry
Hope this helps.
Larry
