Anyone with the mountdirect PMS series wall mount, do you know the precise height measurement of the plate that mounts to the wall?
I'm considering this mount, but am not mounting to a wall, but instead a couple beam on the ceiling. (cannot mount to the ceiling as there is no attic- the ceiling is the roof, so I can't drill into it). I think this mount will fit, but its going to be tight (like 1/8th of an inch or less kind of tight)- so I want to make sure before I order it.
