Which surround speaker should I set to the same level as the rest of the system?
  • Right surround
    Votes: 0 0.0%
  • Left surround
    Votes: 0 0.0%
1 - 3 of 3 Posts
Hi,
I have the Logitech Z906 5.1 surround sound system, but it doesn't allow me to independently configure right vs left channels. I can only configure the surround channels as one level.
My problem is that my couch is next to a wall so my right surround speaker is basically touching the wall but the left surround is out in the open in the middle of the room. As a result the right surround is louder by about 2.5db, my guess is because of the sound bouncing off the wall next to the right surround speaker directionalizing it, while the left surround speaker's sound is spread in multiple directions.
My question is, knowing that the right surround speaker will always sound louder than the left, should I set the level of the right surround speaker to that of the rest of the system and have the left be lower, or should I set the level of the left surround speaker to that of the rest of the system and have the right be louder? For extra context, I did my measurements sitting in the middle of both speaker's (which is the middle of the couch), but I always sit next to the right surround speaker (on the right side of the couch) when watching TV.
Thanks in advance.
something like this https://www.monoprice.com/product?p_id=8231
hook up A zone to the left speaker and B zone to the right speaker, turn on A and B zone from the same input
turn up surrounds on the logitech
then you can adjust volume on the selector for each side individually
Discussion Starter · #3 ·
Interesting solution I hadn't thought of. I'm going to see what other cheaper devices I can buy to alter the audio of the left surround channel.
Until then I will keep the right surround normalized so that I have 4 normal and one lower rather than 4 normal and one higher which may overpower the others
1 - 3 of 3 Posts
