I have not profiled a meter before but am considering getting the i1 Display to pair with my Colormunki to give faster readings, readings into lower light, and no dark calibrating...
So my question is, how EXACT does the point of the screen have to be that both meters are pointing at? I am not sure how I would know that both are hitting the exact same spot. I am concerned because I have a retroreflective Datlite HP screen where angling the meter even slightly from an optimal spot can vary the luminance reading by a ftL or more. So does different luminance affect the profiling, or is it only looking at x and y readings, which I don't THINK change depending on the angle or spot at which I point the meter?
If I truly have to hit the exact spot with both meters then I am not sure how I could do that with certainty. Surely I am imagining this to be tougher than it really is...
