Originally posted by George Thompson
Trucks using Sony MVS-8000A switchers can control multiple switcher processors for several formats through Control Lan functions. Cameras change format with internal presets and auto setup, monitoring is autosetup also. Test signals are sent through the chain to initiate format changes. It takes a little time to change format, but is SOP for a busy crew.
Just went through a Sony Switcher class.
GT |
Presumable the multiple switcher control is more to allow separate SD and HD mixes - say to feed in-vision screens using an SD mix whilst keeping the HD mix for the programme chain?
Or is it conceivable that simultaneous production in 1080 and 720 (rather than conversion from one to the other) would be required?
Pressumably standard switching is done on a production by production basis - so a single HD standard is used for a given job? But different jobs for a truck might require different standards?
Out of interest - how do monitor stacks cope with the 1080/24/25/30p signals ?
Assuming interlaced CRTs are in use I had kind of assumed that the progressive stuff would be monitored in 50i or 60i - with the 24p stuff either 48i or 3:2 pulldown 60i? I had kind of assumed that monitors don't display a 50p or 60p signal progressively, and 25p/30p would be too low a rate for a progressive signal.
I know some trucks use progressive plasmas for some monitoring - but I would assume that the camera guys get a high quality CRT for colour balancing etc.? (I know a common complaint in early European trucks was that some production monitoring - even some vision monitoring - was SD not HD...)
