1 - 5 of 5 Posts
So I'm planning a small dedicated media room, and am going to be doing isolation clips, double dry wall, and green glue. The question that keeps coming up, and one that I don't have a solid answer for yet, is what does the builder do with all the outlets, switches, and wall plates that are planned in the room?
Am I going to need to build a backbox for each of these, and then they mount inside of that backbox?
What if they need a stud to tie to?
What if the wall plate is only a mud ring, and no electrical box?
If they use retro style electrical boxes, will that pass inspection on a new construction home?
How have your outlets/switches been done in your theater/media room?
Thanks guys
RETIRED theater builder
It is actually possible to build a theater with no wall pentrations for the outlets and switches. You have to put them in columns, riser, stage and surface mounted behind a screen wall.
Put that is not always possible so PUTTY PADS
Originally Posted by BIGmouthinDC  /t/1467640/question-regarding-an-is...alled-room-and-outlets-switches#post_23187328
well I answered that last night in another thread
And it was much appreciated
1 - 5 of 5 Posts
