Status
Not open for further replies.
1 - 2 of 2 Posts
I have a question regarding the distances the antennas cover vs. the color code zone . For instance:
1) C.M#3016 has 24 elements cover 45 miles for VHF & 30 miles for UHF with the following color code: yellow, light green, dark green & red.
2) R.S #VU90XR has 26 elements cover 90 miles for VHF & 70 miles for UHF with the following color code: yellow, dark green.
So, if you live about 20 miles from the transmitters and you want to get channels from the light green & red zone which antenna should I get ? Which is the better antenna based on their specifications? Thanks.
Not sure but you can pick up a RS VU110 or VU160 on close out for $2.97. It couldn't hurt to try these first. Boom elements are 32 and 42. Check out my thread.
1 - 2 of 2 Posts
Status
