Status
Not open for further replies.
1 - 2 of 2 Posts
Hey all,
Do any of you fine folks know what the differences are between the SONY KP 61hs30 and KP 61hs20? As best I can gather from the SONY website, the only difference is the audio section. Is this correct?
Thanks in advance,
-Jim
Jim,
I must assume you got you answer by now, but
hs30 protective screen 20/channel audio
hs20 no protective (glare) screen 16/channel audio:)
1 - 2 of 2 Posts
Status
