1 - 3 of 3 Posts
I have an IR distribution system set up on a rack of gear that is currently controlled from another room. All of the outputs of the devices for that room are HDMI. I have distributed the component A/V of my Sat RX to a 2nd room and would like to control it from there also. Trying to do this on the cheap, I have an idea and would like some opinions on whether or not this will work.
The IR system only has one input for an IR receiver. Would it be possible to splice 2 IR receivers into one cable and plug that cable into the IR system?
I know I could go by a wireless IR extender, just trying to pinch some pennies around the holidays.
Thanks for any input and Happy Turkey Day!
1 - 3 of 3 Posts
