1 - 2 of 2 Posts
You are in the wrong forum, post in Plasma, but what you have is IR and it will go away. How long depends on what settings you were using when you played the game. "If you were in Vivid it will take a lot longer than if you used one of the other modes. BTW, stick with plasma much better motion and performance.
Post over in the appropriate plasma forums to get advice on your specific model.
1 - 2 of 2 Posts
