Ok, as suggested in the What happened to the "How To Rip & Stream Movies for the Average HT Guy"m thread , I'm going to start a new thread that will help me (and others) with what options are available for both whole house audio/video distribution and video streaming to my future dedicated HT. These questions may be better asked in either the HTPC forum or the Home A/V Distribution forum, but I'm only a bit tech savvy, so I was hoping it could be explained in layman's terms.
First a little background. I purchased my house back in 2003 it's a 1950's single story 2 bed one bath house. It used to have a single car garage that was (before I bought it) converted to just a utility room, making the house 1078 Ft^2. We've used the space as a home office, storage area, and a place for our cats to hang out in. Last year we decided to add on to the house essentially doubling the size. That will free up that space for me to make my dedicated HT. Other than the foundation, framing and roof, we're doing all the work ourselves (so its going to take a while), and right now its basically open framing. Part of the dedicated space will be a room to house all the equipment. I also figured this would make a good space for the whole house distributionbut I have very little knowledge on how to, and what I would need to make this happen. One of the problems is that we don't have a ton of money to spend on the distribution project, so I'd like to find the best bang for the buck products.
Also right now we only have one TV, and other than the HT plan on keeping it that way, but want to be able add TV's and such to other rooms.
So without further ado
Here's what I think I want to do (or at least as a future upgrade).
1) Whole house audio with source control and volume control in each zone. I'm pretty sure something like this will work, Whole House Audio (for those of you that are too lazy to click the link, it's the mid-level system from Home Theater Direct), I'm running Cat5e and speaker wire to each zone.
2) Wired distribution of Satellite TV (Dishnetwork) I know this gets complicated with receivers and TV1 and TV2 etc, but I'd at least like to have some functionality, I've run RG6 to each location, but don't know what the other ends would plug into.
3) Media streaming via a NMT (Networked Media Tank, such as Popcorn Hour , for those that didn't know what NMT was). I've started this by (or planning on) running Cat 5e to locations that seemed appropriate, like the living room, HT, bedrooms, and home office.
4) Standard wired Ethernet network. Cat5e runs, to a network switch.
I think that wraps up the house distribution aspect of the project, now about the dedicated HT, which I haven't even fully demolished yet, so I know its still a long ways off, but I've been gathering gear as I can afford it.
The room I'm planning will be a Room within a Room design with an interior of 11'W x 18'L x 8'H, I haven't fully set the room length yet because of the before mentioned equipment room. I'm looking at a 100 to 110 wide AT screen CIH 2.37:1 with a false wall. Probably a Seymour AV DIY. To keep within my limited budget I'm looking at the Panasonic AE3000 and the zoom method for CIH. The speakers I'm going with Emotiva's ERM-1's for LCR and ERD's for surround. They will be powered by a Emotiva LPA-1 (for now), and the Pre/pro duties will be handled by the UMC-1 (when it comes out). For the sub I'm also planning on going with the Emotiva ERS 212 (when they come out). I've also got a Panny BD30, Toshiba A3, Oppo DV 980H, and I've got a Dish ViP 722 that I'll probably hook up out there too. I'm thinking about two rows of seating, one with comfy home theater couches, and the other row more traditional theater seats. I do plan on starting a dedicated thread chronicling the progress, in the future.
So here are some other questions.
I think I want to go with a NAS device for storage (no talk of rips here), is it possible for me to build my own? Or is it cheaper to get something OEM like the one from HP? I've built my last 3 PC's from newegg parts, but don't really know what is required for a NAS. What OS does it run? How powerful of a processor is required, how much ram is needed? Etc. It will need to store and send out large video files of HD quality. Is 100 mb/s fast enough or should I wire for gigabit? Will gigabit run over Cat5e? I'm sure most of these answers I can pick up from the HTPC forum.
I've got a Harmony One remote, will I need IR extenders/repeaters/blasters (is there a difference), to control the equipment in the other room? What should I run cable wise to make sure I don't screw myself?
I'm also running phone lines to one central location. Is there a distribution block that is for telephones? Like a network switch, but different?
Holy crap, I just realized how out of control this post has gotten.
I'm sure more will pop into my head as I go along, but at least it's a start.
TIA for taking the time to read my lengthy post on the subject. Thanks again to CDLehner and his thread that was removed, which would have been a good source for much of this information. So on that note please no discussion of ripping, ripping software and such, I can find that through other means (google).
And to Suntan, at least I didn't ask about GG or bass trapsyet.
Oh and if the mods feel its necessary to remove this thread, or if it need to be moved to one of the other forums, that's fine too.
