Ok, I have an Anthem AVM-40 ordered from my local dealer, but while I am waiting for it to get here, I have been trying to get HDMI working at least partially. Right now I am trying to get 2 devices working - Sony Playstation 3 and Toshiba HD-XA2 players. Since I don't have a HDMI pre/pro yet, I am feeding the 2 HDMI sources into my Crystalio 2 video processor (via HDMI, of course) and then I taking the digital coaxial audio output of the C2 and feeding it to my current pre/pro, the Lexicon MC-12. This is working, but only partially. I am not expecting multichannel PCM to get passed, nor am I expecting Dolby TrueHD or DTS Master HD to go through, but I did think that I should be able to get standard DD 5.1 and DTS to pass.
What happens with the PS3 is that I am getting what sounds like left and right main channels of a 5.1 mix passing through properly, but I am not getting and center, surrounds, or subwoofer information. On the HD-XA2 I am getting what sounds like a stereo downmix which the Lex sees as a stereo signal and is correctly applying Logic 7 post processing. The sound from the PS3 has no dialog (which would normally be in the center), and is not even usable as listenable mix, while the 2 channel mixdown from the XA2 is at least usable, though nowhere near as good as a proper 5.1 channel discrete mix.
I have posted in the PMS (Crystalio 2) forum, but there is very little traffic there, so I figured I would try here. Since most people will not know the specifics of the C2, I though I would ask more generic questions.
1. Are there any HDMI "rules" which are stopping the full 5.1 encoded bitstream from passing into the C2 via HDMI and out of the same processor via coaxial digital or is this an issue specific to the C2?
2. Once I have the Anthem here, which will input HDMI audio and video, should I then be able to pass DD 5.1, DD +, and DTS digital bitstreams, as well as multi channel decoded PCM on to the AVM-40?
3. A little OT, but...Can DD+ be transmitted over standard digital connects and decoded by the Lex? Or does the pre/pro have to specifically support DD+ (as opposed to standard DD)?
4. Any other HDMI "quirks" and "rules" I should be aware of?
My eventual plan is to feed the C2's 4 HDMI inputs with 4 HDMI sources and send both video and audio over those connects. Since the C2 has 2 HDMI outputs that can be configured independently, yet run simultaneously, I would like to send HDMI output #1 from the C2 to my display device. Then I would like to send HDMI output #2 from the C2 to the AVM-40 for audio processing. Since there will be no display device connected at the end of the AVM-40 chain, if I understood correctly there is a way to configure the AVM-40 to "fool" HDMI into believing that there is a display connected anyway.
Will this work? And if so, what and where is that setting in the AVM-40?
I sure hope all of this works...
