Status
Not open for further replies.
1 - 3 of 3 Posts
A few questions.. Hopefully someone can answer a few of them!
Am I correct that the benefits of a Torus screen are:
1- better corner/edge focus
2- brighter picture in center viewing area due to screen cupping inward
3- better arrangement for high-gain screens (less hotspotting in center, less light dropoff at outside edges, due to angles)
and.. are there any more benefits, other than bragging rights? :D
My other question- Do the Torus screens require a high-gain screen to realize benefits?
Would a Torus screen be any improvement over a flat screen if a low-gain screen is used, such as a traditional 1.0 gain paint, or a blackout cloth type material?
- David
Discussion Starter · #2 ·
*bump*
SOMEONE has to know SOMETHING about these screens!! :)
- David
Hi David. I've built a Torus screen and can answer some of your questions. Your assumptions are correct except for the corner/edge focus. With my projector, an NEC 1352lc, it was very difficult to get good corner focus. The HD18 lenses could not focus. I ended up changing to HD145 lenses. Now the focus is as good as on a flat screen. I doubt that you would get better edge focus with other lenses.
You need the curved surface to compensate for the characteristics(hot spotting and color shift) of a high gain material. It would not make sense to use a 1.0 gain screen material. You would only make convergence, focus, and geometry more difficult with out any improvements.
1 - 3 of 3 Posts
Status
