Status
Not open for further replies.
1 - 1 of 1 Posts
Hi Folks,
For The Past year I been preparing to convert our Garage into a dedicated theater. So we finally emptied out all our junk to start construction.
The garage is all concrete and our plans are to build a room within a room here. The Ideal inside dimensions of the finished Room will be 20' x 16' x 8'-6" Ceilings. The walls would be built off 2" x 6" Plates/headers with Staggered studs and double layered sheetrock with Green glue in between and insulation inside the walls.
My question is, Since the walls and ceiling of the garage are all concrete, would it be necessary to sheet rock the outsides of the walls as well?
I attatched an image of the Garage layout.
http://www.loutrixrecords.com/garage.jpg
1 - 1 of 1 Posts
Status
