Originally Posted by misfit410 /forum/post/0
Also be careful with the D-Link software if you use it.
it will auto update to 1.09 and stop seeing media..
if you do a clean install of 1.09 it's fine, if you update, it goes nuts..
had it happen on 3 seperate computers.
Originally Posted by lawrence07 /forum/post/0
Hi Everyone
Try putting both files on a usb stick then power up dlink. It works
Lawrence
Originally Posted by bnieman /forum/post/0
Would changing to the "Windows Media Connect" or "TVersity" media servers have any effect?
TVersity sped up navigation considerably, and songs are now in the right order. Unfortunately when an album is done playing it just stops... it does not go to the next folder! Also, it still would be nice to have "Jump to letter X" button of some sort...
TVersity still supports Xvid and Divx just fine. The application you install on your computer runs in the Flash Player so it is a bit unstable, but works nonetheless.
Anyways, I recommend TVersity over the D-Link Media Server.
