Great diagram.
The DC-04 clips are primarily for double stud wall construction. If you were to build new 2x4 walls inside the perimeter of existing walls.
In your case, you would simply modify the existing single stud walls to staggered: http://www.soundproofingcompany.com/..._construction/
No use for the DC-04 clips in this scenario.
The doors create a great big acoustic hole, so having so many may defeat your decoupling efforts.
