The R-DES does look a good alternative to the BFD. However I would like to request these questions/suggestions to ACI..
1) Can subsonic filter can be disabled? (I have a sub sonic filter already in-line)- if it currently doesn't, please add this ability to do so
2)Crossover can be disabled (crossover is in the av pre-amp) if it currently doesn't, please add this ability to do so
3) The large number of sine wave results can be entered (sine waves in 1hz increments, or all those from snapbugs site) into the unaltered graphical section, you can then select the sound pressure meter used- correction values are built into the program (and will correct more than the 21 values of the excel worksheet)
Would it be possible to the unit to have six filters if sub sonic filter and crossover is disabled? (overall CPU load less if disabling those features?- therefore reserve can go into more filters?)
thanks
thanks
