1 - 6 of 6 Posts
Premium Member
Discussion Starter #3
Originally Posted by whiskey > work /forum/post/14335155
that's pretty sick! Too bad the wireless wheel isn't of a higher quality, not your fault of course
Thanks for the comments. The wheel isn't too bad IMO. I mounted it by drilling through it. I put long bolts through the drilled holes and into the wood shelf.
I just wish that game would support it better. Forza 2 and Burnout Paradise City work very well with it. Need for Speed Carbon is almost unplayable. If you could adjust the sensitivity it would play a lot better. On Carbon, you barely move the wheel and the car moves a lot.
dang dino u rule, go av123!
That is way cool! Excellent work!
1 - 6 of 6 Posts
