1 - 4 of 4 Posts
This has been driving me crazy. After the PC has been on for a while, the HDMI audio just plain dies. I sometimes get a warning screen letting me know there is an issue with the HDMI/DVI adapter.
Has anyone figured how to fix this issue?
Mike
Premium Member
Is this a hardware or software issue? Did you try to disable/enable or uninstall/reinstall the HDMI device? Restoring a system image (if you have) is a perfect solution if the issue is software.
Premium Member
Hardware means the HDMI audio tramsitter or controller in your card is broken. (Try to install Windows in another partition and see if HDMI audio works.)
1 - 4 of 4 Posts
