Status
Not open for further replies.
1 - 3 of 3 Posts
Hi all, I am currently using a Radeon 7200 With a 8 inch gun CRT. Would the Radeon 9700 give me better VQ over the 7200? Would it be slight or more signifigant? Do they make a comparable card without all of the features, I watch DVD only on my system...Thanks..
I went from a 7200 to a 9500 Pro. Slightly better PQ. The 9500 Pro handles a wider range of settings, so if you are just going to use the same settings, it might not be worth the upgrade. I saw them at Best Buy for just under $200.
I got a chance to A/B a 7200 and a 9700 on my projector and thought the picture on the 9700 was noticeably crisper. Just to check, I asked the wife and she agreed. Strangely though, she preferred the image from the 7200...
1 - 3 of 3 Posts
Status
