Status
Not open for further replies.
1 - 1 of 1 Posts
Is the 9000 Pro compatible with either the DVI to HDTV Component or VGA to HDTV Component adapters ATI sells?
I have a Panny with no DVI in, and the 9000 pro. I know the 9000 is based on the 8500 chipset, but nowhere does it state if this card is compatible with the adapter. Specs indicate it might be because they state it drives YPrPb.
Chris
1 - 1 of 1 Posts
Status
