Status
Not open for further replies.
1 - 4 of 4 Posts
All,
if I switch to a resolution of 75hz (1024*768) I notice waves on my screen of my projector.
Even when I hook on a tft screen I get the same results: again "horizontal waves" .
Did somebody have the same experiences at this resolution and why does it happen?
nikkieneuken
Discussion Starter · #3 ·
tried that one. no results.....
I also set up the resolution defaults for 75hz in powerstrip recommended by toshiba, so that also not a possible issue.
if I kick in a higher/lower resolution then 75hz it's gone.
the weird part is that 75hz is the only one where I have to set the synchronisationsettings of the monitor to + (hor and vert)....
does it have anything to do with that?
I A SUGGESTION IF YOU ARE USING DVI, IN THE ATI CONTROL PANEL THERE IS A TAB TO REDUCE THE SYNC IN DVI FLAT PANELS PROJECTORS ETC.....
1 - 4 of 4 Posts
Status
