Status
Not open for further replies.
1 - 1 of 1 Posts
I have a question about hooking up my radean 9800 to my hdtv.
I have a 55 mitsubishi widescreen that I have used before with an RGBHV adapter on the end of a 30 foot VGA cable (shielded) and powerstrip. I recently replaced my PC with a newer one, and it came with a radeon 9800 (not the pro). There is a VGA output (primary for monitor) and a DVI output (secondary for my HDTV). It looks like ATI sells a DVI to ypbpr adapter, which would work for me were it not that my TV is a long ways away, and the best route is through the VGA cable (which runs through the wall)
Here are my 2 thoughts:
1. Get a DVI to VGA adapter and try using the RGBHV connecters. Will the ATI card recognize this, or am I forced to get powerstrip? I'd prefer the next option if it would work, since it seems more "ATI supported"
2. Get a DVI to VGA adapter, run it on the VGA long cable, convert back to DVI near the TV, and add the ATI DVI to YPBPR adapter. I don't know much about the VGA to DVI adapters, but do they "lose" some signal where this might not work??? Where would I get decent adapters?
Also, any feedback on using the ATI adapter on an HDTV in general? DVD playback thoughts?
:confused:
-Tom
1 - 1 of 1 Posts
Status
