Status
Not open for further replies.
1 - 4 of 4 Posts
Depends...
If you're going to be doing some gaming, then the answer is yes.
Other wise, a 9500 or 9700 is a much better bang for rhe buck.
Andrew
Discussion Starter · #3 ·
Most likely little to no gaming. I am using it for DScaler and DVD Playback. The price isn't going to bother me if the 9800 pro will outperform the 9700 pro.
Mike
Originally posted by midi-guy
Depends...
Andrew
1 - 4 of 4 Posts
Status
