Status
Not open for further replies.
1 - 3 of 3 Posts
Hello all
When I change the settings in dvdgenie for the ati player and push on apply it reset everything and got a message that cinemaster use also the windows regioncode.
Can sombody help
Rob
Use the cinemaster tab to set up most of the settings - the ATI player is the cinemaster player inside. Just use the ATI tab to launch the player
Its not what you do - its the way that you do it
Besides, you must make the Windows region the same as the Cinemaster region.
1 - 3 of 3 Posts
Status
