I just purchased the newer Radio Shack 4-way A/V selector with auto sensing. The manual input selection button seems to do the job OK, but there appears to be a flaw in the auto sensing. The VCR input takes precedent over all other inputs except for AUX and DVD, even if NOTHING is plugged into the VCR input! This is a deal breaker for my setup, so I'll be returning this poorly-designed device.
Anyone have this unit, and if so, how did you deal with the phantom VCR sensing problem? I brought the first unit back and exchanged for a second, only to see the exact same problem!
The other problem with this device is to use all 4 inputs, you have to utilize the AUX input on the FRONT of the unit! This forces you to flip the lid up and have ugly wires sticking out the front and wrapping around to the back! Horrible design idea... would have been nice to have the OPTION of using the front, but also having a parallel set in back for normal setups.
