I recently purchased a Zenith HDV420 and a Radio Shack conventional antenna, which I mounted in the attic. HDTV reception was marginal, and I couldn't orient the antenna to receive both the standard commercial channels (98 degrees, according to antennaweb) and PBS (128 degrees). Figuring that a less directional antenna with an amplifier might help, I purchased the new Radio Shack amplified antenna, installed it in the attic alongside the existing antenna, and connected it both through a combiner to the HDV420. Now I get a pretty strong signal on all HDTV channels (though occasional dropouts on some channels). However, I notice that on PBS HDTV broadcasts, when there is a lot of movement in the scene, the picture pixellates. When the scene is relatively stable, the pixellation stops. Is this due to some distortion induced by the Radio Shack amplifier? If I replace it with a CM 4221, recommended by some members of this forum, will I have the same problems of inability to receive the stations at 98 and 128 degrees? And if so, how can I address these problems? TIA for any assistance.
