1 - 2 of 2 Posts
When I view movies(ie Hellboy) there is a constant rattling which comes with the low frequency scenes. It is driving me nuts. It is a clanking like sound.
I called Klipsch. Customer service/tech support told me it was not normal but they offered no solution.
Is the sound from the passive radiators?
Am I stressing the sub? Is it too loud?
I set the gain at 0db and then set the sub at -7.0db on my receiver/pre-amp. SPL meter was used to set level at 78db(I know +3db hot)
Any Ideas?
Any Ideas?
At what output does it make noise?
1 - 2 of 2 Posts
