1 - 2 of 2 Posts
· Registered
Ok, here's my problem...
I have an RC6 remote control from Linksys that works great on Windows media center and Xbmc.
I used the "learn" mode to add each buttons into my RC003SR Marantz remote control.
(My Marantz remote can control my tv, my dvd, my tv tuner, etc..)
The control works only once then stop..... ie: I press the right arrow, it work once then doesn't work anymore.
Does that mean the RC6 codes are differents from normal IR remote?
Thank you.
1 - 2 of 2 Posts
