Status
Not open for further replies.
1 - 5 of 5 Posts
Banned
Hi
I have the RCA DTC 100. I have Directv connected to it, on antenna input A, i have a rooftop antenna attached to it and on antenna input B, i have Dish Network connected to that. This allows me to toggle between all three without any problem. However
I can only toggle either between Input A and Directv or toggle between Input B and Directv
This means I cannot toggle between A, B and Directv. I have no idea why and when I called RCA, they didnt have an answer for me.
Anyone know what to do. I can switch to A or B by going into the menu system, but of course, I would rather do this through the remotes input button
Easy fix.
On your RCA remote you have an antenna button.
Press that to toggle between ant. A and ant. B.
Also, when you press the info button you can switch between DTV and TV Ant. by the icon control in the info screen.
You can also set up your remote thru the menu guide on the RCA dct100 to have the fetch button be your source select between HD monitor or composite output.
Enjoy:)
...and when in doubt read the manual.
http://support.tandy.com/support_video/59813.htm
1 - 5 of 5 Posts
Status
