RCA RCU100B universal remote HAS Replay codes
330 Views 2 Replies 2 Participants Last post by  uncleblaine
Just picked up the new RCA RCU100B backlit touch screen universal remote today and discovered to my glee that it does have the Replay codes in it despite the fact they are not listed. All the keys are there, though some are not able to be well labeled. The labeling system allows several choices for each key, and they don't always coincide well with their Replay functions, but for the most part they do. The remote will handle 9 units, does learning, and allows programming of up to 9 macros. It's no Pronto, but for $99 bucks, it's pretty powerful.
Couldn't find it on the RCA website, but here's a link to a snippet from the remote central site:
http://www.remotecentral.com/wn011008.htm
Status
Not open for further replies.
1 - 3 of 3 Posts
Out of curiosity, what is the setup code for Replay?
The Replay code is 148. But I could only seem to access it by code search method. After getting it and checking it I tried to enter it manually and it wouldn't let me. I just went through the search again. I'm using the DVD button for the Replay if that makes any difference.
1 - 3 of 3 Posts
Status
